Roadmap
Suggest a Feature
Account
Login with my account
Trending Top Newest Oldest
142
Open
83
103
Compare two captures
Open
32
89
Open
39
86
Repeated trigger capture
Open
49
83
Import .logicdata capture
Open
40
60
Overlay 2 or more signals.
Open
17
57
Open
48
56
Open
13
56
Open
11
48
Open
27
