57
Alexander Amelkin
There is an idea for Logic 1, but it looks abandoned: https://ideas.saleae.com/b/logic-1-legacy/offer-linux-builds-for-arm-arm64-and-power/
A version for Raspberry Pi (ARM) is definitely needed. At least a data gathering agent would allow to set up a cheap and effective probe for remote debugging of noisy or massive/hard-to-relocate/hard-to-access equipment.
Potential Windows ARM Workaround:
A potential workaround on Windows can be found in the forum post below. https://discuss.saleae.com/t/microsoft-surface/3043/5
discuss.saleae.com/t/microsoft-surface/3043/23
"I also would welcome Saleae on Windows on Arm."
(Surface Pro 11)
discuss.saleae.com/t/microsoft-surface/3043/22
"Would be very much welcome to have Saleae on Windows on ARM. I was skeptical at first but this Surface Laptop 7 probably nicest laptop I’ve ever had, and runs basically everything I need except Saleae."
discuss.saleae.com/t/install-for-raspberrypi-5/3120/3
"Can we have something like this: server running on a Raspberry Pi with a Saleae analyser attached on USB
Logic2 is running on a PC (as a client) gathering data via LAN from the Raspberry server
In such way we can have a more portable analyser without sacrifising bigger displays and better views."
  • M
D
Daniel
Can you comment on the progress / development pipeline for Arm Linux support (aarrch64)?
This would greatly simplify interoperability between our product (a generic test system for microcontroller software) and Logic2.
We have no updates on this yet unfortunately as we're currently focused on other priority projects at the moment. We'll share any updates we have on the feature request post here once we have updates to share.
With the Snapdragon X Elite and Linux support, this topic will get even more important. I started using an arm64 on Ubuntu Concept as my daily driver and being able to use the Saleae would be a major plus.
F
Franco
This would be really cool.
discuss.saleae.com/t/install-for-raspberrypi-5/3120/2
"Wondering if there are any installs that can run on the new RaspberryPI 5? Running 64 bit?
So far feels like a great upgrade from the RPI4s and before. I am playing with one with
NVMe 512gb SSD and works well so far for secondary development machine.
That is, on it, I now have the normal stuff, plus:
Arduino IDE: both 1.8.19 and I built 2.3.3, including boards GIGA and Teensy
Arduino_CLI
SublimeText
VisualStudio Code, with Arduino plugin.
OpenMV IDE.
Now mainly just missing the Logic Analyzer."
(#91746)
User requests for support on Windows 11 ARM 64 (surface laptop 7)
P
Peter
I asked if there was any chance of an arm version for raspberry pi as I want to put the saleae near some hardware and not have to work next to it. I guess you could come up with a new saleae device that streams over WiFi or ethernet, but that sounds more complicated.
"Guys -
Why doesn’t Saleae install on Microsoft surface? It installs the pre-requisite Windows C++ redristributable, but then withdraws the install. ALL of my other apps installed fine, and the surface has an x86 to ARM converter in it. So - what gives here. I NEED SALEAE IN THE LAB BADLY."
(#90652)
"we use ARM64 PCs in many places, so support for this is desperately needed."
M
MikeP
Peez make Logic 2 work on Raspberry Pi 5 fren :D Sigrok already has ........
jason
The program of logic cannot be installed on the ARM PC. I changed the emulation but it still doesn't get installed. Please support me quickly. We really need to use it on the ARM PC.
  • A
B
BK
Hello. As some people mentioned, WOA (Windows on ARM) laptops are entering the market. And I am hoping to have a chance to run Logic Pro on my Galaxy Book2(Qcom Snapdragon). :(
  • A
T
Tom
I'm using Asahi on a Macbook Air M2. Up to now I've been pleasantly surprised by the arm64 binary support vendors are providing (eg. Canon, Jlink and Arduino). Please consider adding arm64 linux to your builds.
Ayke
It's not just the Raspberry Pi 4. There are many newer laptops with arm64, and the Asahi Linux project is porting Linux to the new ARM Macs.
I personally use a Macbook with Linux and can't really use Saleae Logic at the moment unless I reboot to MacOS.
Considering that macOS/arm64 and Linux are already supported, it seems like adding Linux/arm64 support shouldn't be too difficult.
  • T
X
Xander
I would like to use the Logic16 on my robot, while I remote into it with NoMachine. It has an Nvdia Orin Nano 8GB board, running Ubuntu 20.04. It would make debugging the servo bus a lot easier.
(#84120)
"I cannot seem to find the right version of Logic 2.4.10 to install for my Windows ARM device.
I keep getting Warning 4154 on install attempt"
(#82584)
"I wasn't able to find a solution that would allow me to use an ARM device running Linux (eg. Raspberry Pi) to control my testing. Do you have software that runs on Aarch64?"
(#82094)
"I was very happy to see the software release for macOS that natively supports the Apple silicon. Is there any plan to develop an iPad app for the Logic 2? I have this question because Apple has opened up a SDK called Driver kit for device manufacturers to support their devices on the iPad. Seeing that you already have an app for the M1/M2 for the Macbook, I was curious to know if there's a plan for an iPad app in the near future."
Starting Logic 2.4.8, we now provide a native Apple-Silicon build of our software!
www.saleae.com/downloads/
  • Avatar
  • A
(#81445)
"Just picked up my first Saleae logic analyzer and was really disappointed to discover you're not shipping Apple M1 native builds of Logic 2. A big selling point of Saleae is the excellent software it comes with.
Do you plan to ship Apple M1 native builds of Logic 2? If so, do you have a rough timeline?"
"> Can I know if you are running into any issues with using our software through Rosetta at the moment?
I haven’t done a full forensic investigation but from my cursory analysis it seems that the electron framework shipped with Logic2 is built for x86_64. In my experience, Logic2 has been suffering from the same “x86_64 electron on arm64 via rosetta” issues I’ve had with other apps, namely:
poor rendering performance
weird visual bugs and artifacting
sporadic 0.5-1.0s freezing
I got my M1 Mac mini right after release and got to experience Discord and VSCode (among other electron apps) really struggling in rosetta similarly to how Logic2 is struggling now. For what it’s worth, the issues went away after they released arm64 builds.
As for reasoning:
Logic2 is struggling a bit too hard considering my hardware—I’m not even doing anything particularly fancy
Apple has already discontinued all of their Intel-based Macs
Intel-based Macs are already a minority*: 56.04% of Steam users on Macs are using M1 processors
As a developer myself, I understand porting can be very painful but putting off a M1 native build is just as frustrating for users."
"Another small update: I think I’ve found a bug on the Mac version of Logic2. Unsure if it’s related to rosetta though.
My friend has a Saleae Logic 8 (like mine) and is running Logic2 on Windows. The analysis of USB full speed packets happens in real time during the capture. They don’t on my Mac though, I have to manually do Analysers > Right click "USB LS and FS” > Restart for the analysis to take place."
discuss.saleae.com/t/arm-binaries-apple-m1/1559/7
"I get it that this is an old topic… But being a long time Mac user and having seen this movie before (68k, PPC) Rosetta support will disappear, and sooner than we think. Then, my $1000 logic 16 becomes a door stop or I set up a Linux box (I will not use Windows). One of the reasons I supported this product through two purchases was precisely because of Mac support. It would be sad to lose that.
I fully empathize with your staffing situation. Your products are probably so good because you run a lean operation. My post was an attempt to point out that Apple could put down Rosetta sooner than you might think and with less warning than you might like. They have been known to do things like this before. Since Intel is now totally and completely dead to them look to see how quickly the x86 macs age-out now. My 2016 MBP has been vintage since Ventura released. More will go with the upcoming Sonoma. It’s a “don’t get caught out with your knickers down” situation, as far as I can tell."
twitter.com/jrozner/status/1663750726882033664
"@saleae It's been literal years now. Can we please get an arm64 darwin build?
Just don’t want to have to use Rosetta 2 and want to make sure it’s going to continue to work when Apple eventually discontinues Rosetta 2 like they did with Rosetta"
H
Hunter
Seriously... It's been years. The M1/M2 is a well established platform. And the RPi4 is fast, 64bit, and runs debian/ubuntu now. There is really no excuse to not support these two mainstream versions of MacOS and Linux.
Thanks for bringing this up. I just now linked Mark's latest public statement on this topic from last year, which you can find above in the original post. We unfortunately don't have any updates on this effort since then. It's on our backlog, but due to limited sw dev resources as well as other priorities on our plate, we're not able to prioritize this right now.
(#80278)
"Love the products. I own 2 different Saleae logic analyzers and have been very happy with their reliability and overall quality of the product.
Can you please release Logic 2 to run on ARM for RPI? I think customers really want to run their logic analyzer software on a low budget system like the RPi. I've got this clunky Lenovo ThinkStation sitting next to my bench that I am ready to throw in the garbage. I'd really love to run your amazing software on one of my RPi units. :)"
  • D
D
dford
Thanks for sharing my request, Tim! Looking forward to seeing some progress on this front. If we can convince the business / leadership team at Saleae that supporting additional architecture will yield a higher return on future sales and new release products (and it will), then I think we will see some support for engineers to work on this. I believe there are many compelling reasons to do this now because it allows Saleae to be more competitive in the market. Also, I am certain there are many customers who are willing to help test non-production releases so we can further help accelerate the process.
D
Dennis
I'd vote for a Raspberry Pi version that could run on the Raspberry Pi 4. Also would be nice to have a command line version that could capture traces to be saved for later viewing on either a GUI (on some Linux variant, Mac, Windows, RPi4). Also useful would be crude text mode viewer. Could then be used as a remote test/trouble shooting solution via ssh.
discuss.saleae.com/t/arm-binaries-apple-m1/1559/6
"I’m interested in ARM Linux.
I would like to take a RaspberryPi 4, 3D print an enclosure, and make a dedicated, standalone oscilloscope.
I love the form factor you’ve created, it’s great for travelling. However, when I’m working on my bench, then it’s much nicer to have a scope ready to go without needing my USB ports or colliding with my debugger."
(#80126)
"I'm an owner of one of your Logic 16 analyzers.
I just read this page: support.saleae.com/troubleshooting/issues-with-the-apple-m1-chip
Seriously? The M1 has been available for over two years now. What's the problem?"
discuss.saleae.com/t/logic-2-3-56/1700/4
"Is there an ARM64 build ( RasPi, etc ) of Logic now?"
"Thanks for your openness about the technical challenges. I am sure you can manage them. We would be happy to participate in a private beta and give extensive feedback for using Saleae on Linux/ARM64."
D
Daniel
We would like to use your great logic analyzers for debugging a farm of automated test platforms. They are all running on ARM64 however. Please provide a ARM64/linux build.
Our CTO and Founder, Mark, has detailed some challenges with getting this feature implemented in a forum post below:
discuss.saleae.com/t/arm-binaries-apple-m1/1559/4
"Are there plans to also release native arm binaries for Logic 2?
For Apple M1 there is Rosetta - but that’s not really a long term strategy.
At least for me it would be a deal breaker if there isn’t anything on the roadmap.
So - what’s the plan?"
"I am a small hobbyist and to tinker, my computer is a Raspberry Pi 400 (that is a wonderful and powerful low cost hardware).
For that reason, it would be great if your software "Logic 2" software could run on this ARM based hardware."
(#63881)
"Do you have a version for ARM64 specifically the Raspberry Pi."
twitter.com/phigment_ph/status/1435561122413924360
"@saleae any chance you will make an android app to run your analyzers? It would be awesome to have a small portable solution!"
(#61457)
"Feature Request - phone application and connection to smart phone
1. every person have smart phone and it will be more easy to use smart phone to collect data .
2.some times the problem that can start from some reason at laptop that be because windows or driver .
3.it can be good feature , as a person that use it every day i think that it sometimes help full to use smartphone as a logger and as a display."
Jens
I really think this is a mist have! For my automation this would really be Nice Addition. Raspberry pi with git and Ci Plattform with logic analyzer for detailed signal Verification.
H
Hunter
You need to migrate for Mac M1, and there is no reason not to support ARM linux. Please fix this...
D
David
I would sure like Logic2 to work on my RPi 4b
Apple has now released 3 models of Mac computers with the ARM64 cpu architecture. Despite having Rosetta translation, Logic crashes on launch, rendering the Saleae Logic Analyzers unusable on new Apple Mac hardware.
  • A
M
Matt
I too would like an ARM build; specifically for the Pinebook PRO but generic arm64 would be fine.
  • R
