23
More Complex Digital Triggers (One Shot, Protocol Results / Errors, State Machine)
Anonymous
I'm very happy using the Saleae analyzer
One missing feature (even on the new software logic 2.3.8) is having the possibility to not only trigger on rising or falling edge of the signal
but also trigger on sequential condition or bus value
The NCI logic analyzer supports that.
For example you could only trig if signal 1 is high and signal 2 is low
or if probes 1 to 3 have value 4
or other kind of state machine condition
like if signal 1 rises, then fall then rises gain
Thanks.
(#100195)
"- Puls width => Trigger if detected puls width fals between two time settings. ie puls smaller than >10us and
discuss.saleae.com/t/protocol-trigger-with-custom-analyzer/1212/4
"Is the feature to trigger from within the High Level Analyzer available?"
(#96769)
"Can I trigger follow sequence
when a vlotage above a specific level channel#1, check whether a specific value apears whithin 1second in channel#2,#3 I2C data"
discuss.saleae.com/t/trigger-on-both-rising-and-falling/3350
"is there any way to trigger on falling and rising edges I do have a toggling GPIO to indicate change, while my oscilloscope can catch all events, the Saleae can not because it can only react on ether falling or rising _ it is though very common to trigger also on both. Instead there is the Pulse it is good thing for bus starting tact, but not so much for indicator signals."
C
Charles
Thanks Tim for adding my request. (#95362)
(#95362)
"Can you please implement a trigger on any edge option. While debugging I often toggle an IO and having the ability to trigger on any edge will be of tremendous help."
(#92206)
Request to support multiple simultaneous trigger conditions.
"things like when we have a falling edge on CH3 and a rising edge on CH5 and a high on CH8 and a low on CH 12"
(#86383)
"Could you update the SW or extension with the Logic Pro 8 units allows us to capture data of all channels on any transition state of the channel being triggered? So to add Rising Edge and Falling Edge Option or check those two options at the same time."
(#89425)
"The trigger action can be different for every situation (sometimes
even real-time CAN decoding and trigger on some packet anomaly's). For us it would be the best solution if we can use the Saleae Logic Pro 16 to use it as a fast up to 16 channel ADC from a C/C++ program."
R
Ralf
At the moment only support condition like channel high/low for channels other than the rising/falling edge channel.
It would be nice that it is possible to trigger 2 channel ( or multiple ) , if one channel has a rising edge during the second channel has a falling/rising edge at the same time. ( and logic )
Merged with: Trigger of several edge
R
Ralf
Is it possible to trigger 2 channel ( ore multiple) , if one channel has a rising edge during the second channel has a falling/rising) edge at the same time.
At the momemt, only support condition like channel high/low for channels other than the rising/falling edge channel.
#84744
"I am looking at DMX-512 data, and the ever important thing is the BREAK that occurs every x bytes. Is there a way I can trigger on that?"
(#84024)
"I would like to monitor a nack during an I2C transaction. How do I configure the Saleae to trigger the nack and capture all the waveform."
(#82888)
"Hello. I was wondering if it was possible to stop a capture if the number of rising edges on a particular channel is not met in between trigger signals on a reference channel.
For example, on my current set up, I start the capture on the rising edge of a reference trigger signal (Channel 1). I expect the number of rising edges to be let say 100 on channel 2 in between the trigger signals on c1. If I get less than 100 rising edges on c2, then there is a potential problem with my digital logic and I would like to stop the capture so I can examine where that event happened."
N
NG
It would be great to be able to configure the logic analyzer trigger to stop when a specific SPI byte, or frame type of an HLA is encountered.
discuss.saleae.com/t/new-features-for-asynch-communications-panel/1592/5
"Just wanted to put in an additional vote/request for ARINC 429 decoding.
To the point about the need for ternary logic states, I have an alternate suggestion. If the signal trigger threshold issue above gets resolved then decoding could be done directly by sampling the same signal across two channels. One channel triggers at >=6.5V (0/1 threshold), and the other triggers at
"The ARINC 429 protocol is an example of an asynchronous protocol which uses a 3 level signaling. The Idle state of the bus is approximately 0V. A logic 1 is represented by a signal level >= 6.5V which a logic 0 is represented by a signal level = 6.5V or 0V to
(#73604)
"Hello, I reckon the software should have the ability to search for a specific edge in the data.
For instance:
Search for FALLING edge of CH0 where CH1==HIGH and CH2 transitioned to LOW in the preceding 10 ms."
A bit a sad that Saleae is ignoring my request for 2 years now.
  • N
Sorry we haven't had a chance to work on this feature request yet. We're a small team of 3 developers, and we're currently hard at work adding automation support to the new Logic 2.x software. We're also spread pretty thin dealing with supply chain issues, which has really messed up our schedule.
In the meantime, I've been keeping tab on all users who need this feature so we can compile a list of use cases we would want to support.
(#73574)
"The feature I want is the ability to trigger when the communication error occurred.
For example, Saleae Logic 2 app knows framing error occurred during transfer, when use Async Serial.
So, it would help us to debug and capture error easily, if trigger by error timing."
discuss.saleae.com/t/scripting-socket-api/108/9
"it’d be great if you could trigger on more than one line at the same time, whichever comes first."
(#68070)
"What I want to know is the following :
* Is it possible to develop a custom analyzer that can catch at the same time SPI data and GPIO states ?
* Is it possible to start the capture and analyze on the fly the data with the custom script, reject some, get only what we are interested in, and write a file on harddrive to store results ?"
This use case could be solved In combination with the idea post below:
ideas.saleae.com/b/feature-requests/continuously-triggering-start-mode/
discuss.saleae.com/t/please-allow-for-lower-memory-limit-and-temporary-analyzer-disable/1395/11
"In addition, It would be very nice to see the capability for appending trigger captures, which would help this gentleman. If you had a trigger condition which happens once every 12 hours over a weekend, you would want to capture 5 seconds or 10mS before the event and 1 sec after the event and then go to sleep until the next trigger. So, when you come in 3 days later, you have only 20 seconds of data and 5 events clipped in front of you."
  • D
(#66622)
"in the loop mode when the event of interest occurred the LA can overwrite the event. To fix the problem, the user sets an acquisition period. When the LA is triggered, the LA collects data until the end of the period. If a trigger occurs within the time period, the period timer resets to zero, resulting in the acquisition continuing uninterrupted
the default triggers were not suitable for an undefine events which occur once a week. It turned out that two CAN Frame are received at the same time, stopping the CAN transmission."
(#67007)
"Hi. I'm working with a soft real time processor communicating with a ADC that triggers a IRQ every 1ms.
How ever as the processor is running a soft realtime system I need to be able to trigger if I miss a IRQ from the ADC.
Curretly Im partially successfull with falling edge on GP1n (when my processor interrupt routine is executed) and if nIRQ is high.
How ever best would be if I could define it as "Falling Edge GP1n + no fallinge edge on GP1n for 2ms). This would give me the position of a missed irq from the ADC..."
"Basically if I have a falling edge, and then no other falling edge within next 2ms then I trigger. This would mean that my SoftRealtime processor missed a hard realtime interrupt from the ADC."
discuss.saleae.com/t/show-bus-value/1001/5
"We are also capturing data from an 8-bit port.
For us, a useful feature would be logical operators on the trigger. In our case, trigger on nWR (not write) OR nOE (not output enable). So an OR of 2 channels would be good."
Request to improve trigger view to allow more advanced filtering.
"will it only trigger on a pattern match? Or can you apply some Boolean logic? For example, I would like it to trigger on any value above 48."
Support One-Shot Triggering Based on Protocol / HLA Result. Stop the capture once protocol / HLA match is found.
discuss.saleae.com/t/is-it-possible-to-trigger-on-custom-high-level-analyzer/1201
This is a different use case since it would be running (maybe for days) until an error is detected using my custom HLA then trigger and stop running. Good to have on the feature request.
I think this idea is great! I changed the title to better help us keep track of this request. I also plan to merge a few similar requests here, as I'd like to consolidate all ideas around digital trigger improvements.
For example: Trigger on parity error
Merged with: Trigger on Protocol Error
(#58269)
"I have an RS-485 bus that infrequently produces errors. I would like to set up to capture data (unmonitored) and stop when it encounters an error so that I can analyze the problem with my system."
(#58277)
"is there a way to stop capturing comm data via a parity error? I want to capture a parity error that only happens 2 or 3 times a day."
M
Morten
This could be achieved by having "virtual channels" that are defined using Boolean (on digital) or arithmetic (on analog analog) Expressions.
A trigger could then be added to the virtual channel
