Return to saleae.com
Changelog
Log in
Roadmap
Changelog
Back
2.3.46
Fixed
Improved
N
Neel
on 04-03-2022
Windows
Linux
MacOS
When trying to close protected captures or the application with protected captures you will be prompted to save the capture first.
Removed cursor focus from the comment field for measurements so that you can easily remove a measure using the delete or backspace key.
You can now resize the Timing Marker and Measurement sidebar sections to allocated more space for your given needs.
Fixed issue where pressing the
R
key would crash the app if the Export Raw Data dialog was open
Fixed issue where no channels were selected when opening the Export Raw Data dialog
Login
Account
You have to login with your account first.
Login with my account
