Back
2.3.42
Windows - Linux - MacOS
What's New
  • Support for the upcoming Logic Pro 16 Revision 3.0.0. New Logic Pro 16s will require this release or newer. Due to supply chain issues, we've changed one of the components in the device. There is no functional difference in the new revision.
  • You can see your HW revision in the Device Info dialog.
  • Updated start and stop capture shortcut to the r key to make it easier to start and stop a capture if you only have one hand/finger available
  • Add frequency metrics (1/T) to marker pairs
  • Added delete all timing markers from timing pair menu
  • Improved messaging for device errors
  • Improved rendering performance
