Return to saleae.com
Changelog
Log in
Roadmap
Changelog
Back
2.3.20
New
Fixed
Improved
N
Neel
on 10-03-2021
Windows
Linux
MacOS
What's New
Access and discover shortcuts via the command palette (Crtl-P or CMD-P)
Improvements to HDMI-CEC analyzer (thanks to
guzu
Updated Raw Data Export dialog layout with digital channels listed first & added all / none buttons to make it easier to filter channels
LLAs using the
AddChannelBubblesWillAppearOn
API call will no longer see empty bubbles
Analyzer bubbles now show 400 characters, helping you to see more of your data on screen
Fixed bug where you could try to load a preset on a tab that didn't have a valid device
Fixed issue where very early (late 2014-early 2015) Logic 8s would have about 10% voltage error. Only a few hundred units affected.
Fix Raw Export Dialog showing incorrect analog sample when capturing with an analog sample rate of 31.25 kS/s or below.
Fixed bug where pressing Ctrl+A or Ctrl+C in the analyzer terminal would scroll the terminal to the bottom
Login
Account
You have to login with your account first.
Login with my account
