Multiple Triggers
From other logic analyzers i am used to have more than one triggerable channels, and i'm badly missing something like that here. With the saleae logic analyzers it is only possible to trigger one channel at a time.
So i'm proposing the software/hardware feature to have several, or preferably all channels triggerable.
Vicam Jul 11, 2018
The really old version of logic (1.0.xx) used to allow this, and it was very robust. Multiple signals could be combined, each signal could have 4 different trigger stages, each signal could be high to don't care, high, low, transition high, transition low. So you could make it so that 1, 3, 4 and 7 could need to be high, 2 and 5 low, and 7 transition from high to low, then it would go to the next stage. The next stage could check for 1 to transition from high to low, then it would go to the next stage. Once past the fourth stage, or all don't cares, it would trigger.
KisCsillag Jul 11, 2018
The best would be if the triggers were implemented in HW.
