Interfacing with wireshark disectors live
Being able to use wireshark dissectors for protocol debugging is an indispensable tool. When developing transceiver or MAC layer communications it would be a great help to feed data directly into wireshark as a live stream.
DG Jul 11, 2018
ideas.saleae.com/forums/214303-saleae-ideas/suggestions/7121364-add-lua-scripting-interface-to-control-and-data-co
DG Jul 11, 2018
ideas.saleae.com/forums/214303-saleae-ideas/suggestions/5798328-add-more-functions-to-the-scripting-api-please-ad
Anner J. bonilla Nov 17, 2018
This sounds like a great idea
@dg your links are sadly broken.
Joe Garrison May 23, 2019
I've looked at wireshark and it seems to have quite limited lew-level-embedded support, but lots of higher level protocols including USB and (obviously) TCP...
More information about your use case(s) would be super helpful here! What traffic are you recording that you would like to feed to wireshark?
"When developing transceiver or MAC layer communications" - what protocol layers specifically are involved here, that wireshark supports? Do you envision that Saleae decodes a packets as essentially bit-fields, and then feeds those into wireshark?
