Groups of protocol analyzers should be able to be exported as one file
  • Shipped
Users should be able to export multiple protocol analyzer results into one interleaved file.
Guest Jul 11, 2018
Under the Analyzers tab, just click on the name of the analyzer and you can change its name. That way, when you export, you will know from which analyzer it came from. You can also print data from each analyzer separately by clicking the gear icon to the right of the analyzer name, and select "Export as txt/csv file"
KaiHP Jul 11, 2018
As far as I can tell, this feature works my printing all analyzer output in the same column. If I have two Async Serial analyzers (ie I'm monitoring both Tx & Rx on a UART), I cannot tell which line is from which UART line/analyzer.
Maybe it would be better to write each Analyzer output to it's own column, with the 'inactive' analyzers just printing an empty field.
So you'd have each line being:
