Advanced Triggering
At minimum provide a counter to trigger on the nth event. For example on the 5th rising edge. At best provide if then else triggering across multiple channels.
schmitt trigger Jul 11, 2018
My two cents here:
to trigger on certain protocol events. For instance, if one selects I2C, to trigger at a START or STOP conditions.
Lucas Jul 11, 2018
This, in my opinion, is one of the most important features needed to solve complex issues. For simple checking the edge triggering is good enough, but when you are handling intermittent issues, for example, it's almost impossible to collect the data at the time the problem happens. Adding advanced triggering support would take the Logic to a whole new level of usability.
On top of all the ideas given, I could propose something that would probably be easier and would still be a great help:
If the trigger can free-run with a set time window and only stop when the user manually tells it to stop, one could keep recording until the issue happens, and then stop with enough recording time to go back and check whatever happened just before that. It's the same idea as recording without the trigger, but it should keep recording (and discarding the old data) until the user stops.
Ed2 Jul 11, 2018
Absolutely, this is where other product have the advantage. You have ONE edge and multiple HI LO values on other channels. A count and edge on all channels or at least more than one would be super.
antonv Jul 11, 2018
Also to be able to trigger on any voltage in the analog input range please.
Guest Jul 11, 2018
This is really important to include pattern trigger, sequential pattern (4 is enough for starters) and ORed pattern trigger (trigger in pattern [A or B], [A or BC], [AB or CD] . For a start a pair of one/two pattern sequences would be enough.
RAD750 Jul 11, 2018
This would really be useful! I am a full supporter of this. It really helps when figuring out unknown signals, especially when you want to trigger on one channel (say sync on video signals) and view the actual data sent on another pin.
HansD Jul 11, 2018
Also the ability to trigger on a combination of signals
