R |
Ralim |
Often when recording long captures on a mostly idle bus a large amount of time is wasted during "idle".
Having some way to be able to "compress" these time periods by default, so that they take up less room when scrolling through a long capture would be ideal.
Thinking of some fancy modern version of how you even see in datasheets the small s like pattern on lines to indicate "time has passed".
Maybe it shows a block of a different colour you can click on to expand it back out.
In _most_ protocols data is only transferred on edges / when digital lines are changing.
So sort of thinking if you could specify to "hide" idle periods of greater than some threshold would be ideal.
In my application; I'm logging data to an SPI flash every 30 seconds, which results in a small burst of activity followed by 29.9 seconds of empty space in the capture.
If i could collapse these down I could then scroll through these to check without having to zoom in/out.
discuss.saleae.com/t/delete-data-between-markers/2723/5
"I totally understand the difficulty, you would have to trim the marked area between two markers, then “change” all the post sampled data to reflect the removal of middle data. I’m guessing that you would have to modify the sample numbers after the delete. For me, this is useful to trim captured data to help in the development of the Low Level Analyzer, remove data that is redundant, and focus on exercising each unique piece of logic. Saving huge amounts of time running through already debugged data. Can you export the data, trim, reorder sample numbers and re-import? That would be a short term solution."
(#90143)
"Feature Request - Edit Capture - To reduce volume of data and memory for long capture with only 1% interesting.
my need is to edit the recorded scan like you would edit a video, but cutting/removing the non needed parts with addition of cutting marker..
my demand would permit to save the 90% of unneeded record by cutting them while in the article, the data would still be there and would just be collapsed to avoid scrolling horizontally.
my demand would save time for the user and save space on the saved record."
discuss.saleae.com/t/time-compression-between-changes/2844
"Context: receiving data over CAN at 100 ms periods
In order to analyze what is going on in the timeline view, one has to continuously zoom out, move to the next packet, zoom back in… (and repeat).
Is it possible to compress the timeline between the packets (I tried to sketch the concept below)?"
"Is it possible to delete data between 2 markers? Cant find how.
Tried with a marker pair as well, but there is only the option “outside pair”. I would like to delete “inside pair”.
Working with v2.4.13"
(#84804)
"It would be super useful if there was an option to hide the idle periods to make more use of the screen, when zoomed into each packet of data."
(#80102)
"View different parts of a channel in the same capture
I would love a way to be able to view a sequence several transactions of a digital trace (I2C in the current case; assume everything here is talking about digital captures) that are separated by relatively long amounts of time. When they're visible on the same screen they lack the detail of a higher zoom level.
In general I want to have a way to visually compare sections of the trace that are not on the screen at whatever the current zoom level is.
Possible approaches:
- collapse the timeline between edges if over some threshold
- collapse the timeline between two timing markers
- multiple view ports for the same channel"
Peter
Maybe not make it the default, but it would be nice to have a button that could toggle compressing/expanding idle periods.
