I |
Ilan |
Support of simultanious CAN 2.0A/B and CAN-FD protocol decoding shall be supported. (Controller Area Network Flexible Data rate)
As an engineer I want to transition from CAN to CAN + CAN-FD in order to profit from the reduced overhead of the messages and the improved througput while still able to be using CAN simultaniously on the transmission line. Therefore I want to set the CAN measurement settings only or I want to set the CAN-FD measurement settings which require valid CAN settings. CAN-FD implies and requires CAN.
Additional CAN-FD settings proposed: Enable functionality :Flag Flexible Data rate settings :Frequency Same frequ. as CAN : Flag
Rating: Must have in the near future (imho), same as iic/spi.
Saleae Edit: We made a slight update to the title to make this post easier to find
(#94343)
"Feature Request - CAN FD. i need to caputre CAN FD signal now not available"
Pete
I desperately need a built-in and tested low level driver fro CAN FD
(68959)
"Hello Team,
It would be a nice feature if you could provide/add Analyzers for CAN-FD.
Thank you."
Sharing a 3rd party CAN-FD analyzer that a user created:
support.saleae.com/protocol-analyzers/unofficially-supported-protocols
Direct GitHub repo here:
github.com/acosmith/Saleae_CAN-FD_Analyser
(#57103)
At the moment we require 4x Units from the Saleae Pro 16 and the main protocol to decode is the CAN-FD (most of our customers are moving to this Protocol).
Wouldn't it make sense for you to add the protocol support on the next release ? Since this as been already tested ?
