E |
Erwin |
Markers are currently added in order of creation. It would be great to:
1. Reorder Timing Markers in the Timing Markers window by dragging.
2. Add a menu in the Timing Markers window to sort all markers at start time.
Bruce
I would also like this feature: display markers by timestamp. That would be very useful. The feature of changing the number of the marker? I'm not so interested in that. In fact, it may not be desirable if markers are referred to by number in the notes sections.
Is there an ETA for this feature?
radosalv
I will be very helpful if there will be an option to sort markers by timestamp in "Timing Markers, Measurements and Notes" view.
The other solution may be to renumerate the markers based on the timestamp.
Now it's gets quite messy if one jumps over a signal and marks different events not in the order they appeared.
Merged with: Sort/Reumerate Markers by timestamp
(#95087)
"it would be very nice if when you go to the timing mark tab if you had the option of sorting by time, not just marker number."
discuss.saleae.com/t/timing-markers-list-order/2349
"Timing Markers are assigned an index number when you create them, which appears to be immutable. This means if I create a marker “T0” and then want to create another marker (automatically named “T1”) at an earlier instance in the timeline, it will still appear “later” in the list of markers.
Is there a way to reorder the markers as the appear in the sidebar/list so that they’re in chronological order?"
