6
HLA - Sort / Re-order settings in UI
Jonathan
It seems that the HLA settings appear in an apparently random order in the Logic UI, I think they should be in the same order as they appear the Python code.
(#90096)
"Yet another thing worth adding would be a way to specify the order of settings."
(#84288)
"Can the order, in which the settings for the custom analyzer will be displayed, influenced? The input analyzer being the first setting is fine. But the custom settings defined in the Python class are not shown in the order they are declared in the code. Since I'm using some settings which are logically grouped together, this would be good, latest when making the extension available to other project members."
discuss.saleae.com/t/hla-data-window-field-display-changing-field-order/1878
"I’m modifying/developing an HLA to display information from an I2C Analyzer in a more compact and easily readable format in the Data Display window. I’d like to change the field order, but haven’t found a way to do so:"
discuss.saleae.com/t/hla-extension-ui-settings/1814
"Is there a way to sort the settings listed in the UI of the HLA extension?"
Thanks for your suggestion! We'll keep this on the radar for when we improve HLAs.
