A |
Andrew |
A suggestion for a GUI improvement. You know how some programs have a way in which you can slide a separator window and have 2 views of the same file? (E.g. Excel and some text editors...)
It strikes me if you had a vertical separator that you could slide across either a saved capture or a stopped live session then you could make 2 views of the same data channels. This would enable you to compare data of the same events at 2 different points in the same log, e.g. for analysing "good" and "bad" behaviour.
My workaround is to save the log to a file, then open 2 instances of the Logic program, this allows viewing of the same log at 2 different places in time. Would be better if that was all in the same tab though with 2 scrollbars.
Merged with: Compare two captures
