Peter Jaquiery |
I'd like to be able to set the time at a specific point in the trace to a given time. This will allow me to easily compare event times between the logic analyzer and other test instruments like a Scope, USB analyzer or USB-C PD analyzer etc.
At minimum being able to make a specific epoch the 0 time reference would help.
Status changed to: Live
This is now possible via Time Bar Settings:
support.saleae.com/user-guide/using-logic/time-bar-settings
Peter Jaquiery
Merged with: Trigger time should be at 0
Peter Jaquiery
See ideas.saleae.com/b/feature-requests/set-refere-po-in-timescale/ which was merged with a similar "Trigger is time 0" idea.
Thanks Peter! I'll merge this with your idea.
Neel
Status changed to: Open
Jonathan Gjertsen
Would also be helpful to have an absolute timestamp (so that the time at the start of the capture equals the unix timestamp of when the measurement started), then it could be compared directly with log files from other software without any setup.
Peter Jaquiery
I have a feeling from other discussions that that is already happening under the hood and may be available to HLAs (High Level Analysers). That's not immediately useful to us, but at least hints that there shouldn't be big technical challenges for Saleae to do this stuff.
Merged with: Time is not 0 at trigger point
The time should be 0 seconds at the trigger point, so that it possible to see for example the startup time immediately.
Peter Jaquiery
Status changed to: Planned
