S |
Stuart Rubin |
Using the SPI analyzer, for example, it is common to find some byte, and click the "goto data" button which moves the trace view to the selected byte.
Very often, I require the opposite. I would like to click on the data in the trace view and navigate to those data in the (SPI) analyzer view.
Florin
the option is already implemented, from the main trace view, just hold the CTRL and mouse left click and will send you in the Data panel to the precise position
a popup info appear when hovering over the byte
Stuart Rubin
I see it now! The trick is that you need to click on the hex data, not the trace. This is very helpful. Thanks, @Florin for pointing this out.
