Roadmap
Suggest a Feature
Account
Login with my account
Trending Top Newest Oldest
138
Open
83
99
Compare two captures
Open
32
87
Open
39
86
Repeated trigger capture
Open
49
83
Import .logicdata capture
Open
40
56
Open
13
56
Overlay 2 or more signals.
Open
16
55
Open
48
55
Open
11
47
Open
27
