Currently our Manchester LLA supports the following modes:
- Manchester
- Differential Manchester
- Bi-Phase Mark
- Bi-Phase Space
It would be nice to add support for other modes and variations, such as:
- Bi-Phase Line
- NRZ (M, S, and L)
- DALI
discuss.saleae.com/t/aviation-protocol-decoders-1553-and-arinc-429/3329
"Has anyone in the community created decoders for common aviation standards like MIL-1553 and ARINC-429? These seem like they should be simple to create and wondered if these already exist as supported or community created protocols?
If not, is there a suggested protocol template I could use to start writing my own protocol decoder? MIL-1553 is Manchester encoded. 429 is RTZ encoded."
(#83187)
"Menchester decoding works in general. But when listening to a DALI communcation, all byte values were decoded except 0xff. DALI ansers YES with a 0xff an NO with no response. In the decoded stream this is not visible."
Hans
For DALI to be supported in LLA the main thing that is missing is a 10% tolerance. (I use it with 25% now)
A HLA DALI analyzer that actually interprets the bytes is good to add to the library as well.
If I remember correctly Logic 1 had a DALI analyzer.
Rick
I'd like it to decode DALI
(64872)
User requirement for NRZ/NRZI protocol decoding
To have Manchester analyzer updated so it can support DALI protocol decoding. DALI is made based on Manchester encoding, having a start bit (HIGH -> LOW -> HIGH) that should be ignored and 2 stop bits at the end that should be ignored too. See i.stack.imgur.com/sT7Tl.png
Merged with: Support DALI protocol
Peter Jaquiery
There are lots of protocols that use Manchester encoding as their physical layer transport. Facilitating using HLAs with Manchester analyzers would unlock these. A HLA template for the job that recognized preamble patterns like the start bit mentioned above then pulled out fixed length blocks of bits would handle a lot of the common processing.
My own recent interest was decoding USB-C's PD communications across CC lines. Pulling that fully apart is a big job but could obviate the need for a dedicated PD analyzer.
