There are a few methods for trimming / deleting data from your capture as described below:
support.saleae.com/user-guide/using-logic/delete-data
Both involve opening a right-click menu.
For discoverability purposes, it would be great to include an option to trim via:
- within the options menu (3 lines at the bottom right of the app). This would enable a selection rectangle, which the user could use to draw the area for the data they would want to keep.
- Allow a dedicated window for trim/delete options (specify time range, specify timing markers, etc).
(#73604)
"I was expecting to be able to highlight a range of the capture and then do Edit > Crop, or something similar. I was looking at commands in the menu bar.
I’m probably biased by image editors where you usually select part of the image and the do the “crop” command."
