Roadmap
Suggest a Feature
Account
Login with my account
Trending Top Newest Oldest
147
Open
85
103
Compare two captures
Open
32
91
Open
39
87
Repeated trigger capture
Open
49
84
Import .logicdata capture
Open
42
64
Overlay 2 or more signals.
Open
17
58
Open
11
57
Open
48
56
Open
13
48
Open
27
