Roadmap
Suggest a Feature
Account
Login with my account
Trending Top Newest Oldest
139
Open
83
99
Compare two captures
Open
32
89
Open
39
86
Repeated trigger capture
Open
49
83
Import .logicdata capture
Open
40
57
Overlay 2 or more signals.
Open
16
56
Open
13
56
Open
11
55
Open
48
48
Open
27
