C |
Colin |
Hi, I have Logic 16 and often want to use it to decode 16-bit parallel bus. But ironically you cannot use the Logic 16 for 16-bit bus because you can't see the CLK signal or the framing signal, or the R/W signal.
So we need more signals... Really, Logic 16 should probably have 20 pins. And if you ever make Logic 32, it should probably have >36 pins.
