9
Automation API - Support Post Capture Functions
Original request in Ticket #77063:
"Specifically, beyond starting / starting and saving traces, what I really need to be able to do is automate analysis of user-captured traces in bug reports.
I see there is an API to load a capture, but there doesn’t seem to be much beyond that in terms of:
  • discovery of channels
  • discovery (and subsequent removal) of analyzers saved with the capture
  • modification of parameters for loaded analyzers
  • trimming a capture file
Are there any plans to make the automation API’s more post-processing friendly?
I realize there’s the add_analyzer API but as I read the docs I’d have to iterate through each combination of (undiscoverable) digital channels, load the analyzer with fixed settings and if that didn’t work, remove it, re-load with changed settings etc.
I suppose the iteration across all combos is possible, but it does require the discovery of digital channels in the capture. Is that available somewhere I’m not looking?"
(#99944)
"is i possible to add the pass fail as an analyzer in saleae?"
"Eventually we need to analyze the data captured by checking if it fits inside a mask. so lets say as example we expect a certain wave form than we could in pyhton add some unit test around it to see if it doesnot exceed a lower of higher threshold. (our MASK) basically all we need is a pass.fail out of that."
discuss.saleae.com/t/load-multiple-analyzers-or-a-preset-on-multiple-read-only-capture-files/2692
"We use the Automation Server calls to take multiple captures on a setup.
These files are just plain captures without any analyzers.
After coping the files out we would like to setup certain analyzers but adding the analyzers manually to multiple files is cumbersome.
I tried saving the analyzers as a preset but when I try to call load preset it says “Preset cannot be loaded for read only capture”.
What would be the best way to add a set of analyzers to multiple read only capture files?"
discuss.saleae.com/t/trigger-timeline-and-pre-trigger-trim/794/3
"I was wondering if the feature with trimming pre-trigger data is also on the roadmap? I am only interested in data, that is recorded after my trigger but in the current Logic2 version you are still limited to a 10 ms trim. That is quite a lot of file size overhead if you sample at a high rates and want to do it automatically with the python sdk."
