12
Automation API - Execute automation script on pre-existing session
M
Matt
I'd like a way to trigger a 'start' command in the app through the API, without changing the session settings.
I often use the Saleae logic analyzer for interactively debugging a program. The original API was great for this because I could manually tweak settings in the app, run a script that triggers a capture using the existing session settings, then view the results directly in the app, and rapidly iterate with different settings. With the new API, there doesn't appear to be a way to attach to an existing session, and the capture configurations are not geared towards the GUI. For instance, names cannot be assigned to a channel, and graph size/zoom cannot be set. It would be great if there was a way to just start a capture with the current session settings, like in the old API.
(#93756)
"is there a way to simply start and stop a capture with the current configuration and analyzers? It seems to always start a new session, and I have to add all the analyzers and channel captitions again. I just need a way to remotely “press” the start/stop button."
(#93739)
When using Automation API:
"How can I make Logic remember my custom channel names, so that they are shown correctly when I load a capture file?"
(#87558)
"I want to query the currently active session for its configuration, think of it as copying the active session configuration in the GUI."
(#89470)
"Can I have two separate scripts, one to start the analyzer, and a different script to stop/save?"
(#89446)
"Is it possible to use the automation API where two separate executions of Python first start and then stop a capture?
Right now the API seems to be manager.start_capture() returns a Capture() object which can then be .stop()ed or .wait()ed.
But it doesn't seem to be possible to start the capture, kill Python, restart Python, reconnect and then .wait() or .stop()."
  • Z
(#88461)
"0. Enable Automation API
1. Setup capture settings and analyzers as desired
2. Use automation script to start capture with: manager.start_capture()
Expected result: capture is started with current capture settings, like if I clicked "run" in the GUI.
Actual results: Empty capture is started. No way to use existing configuration. Must specify everything manually in the start_capture() call."
discuss.saleae.com/t/automatization-changing-label/1955/12
"if I could just use the settings from the current session, that would be awesome. Use case is that I have already configured things manually and run a few times, now just want to automate running the same test over night, saving data after each trigger."
(#86367)
"i am trying to automate the logic analyser logging. i would like to pause and resume the logging in the same session. now i use the methods start and stop which opens new session of log every time."
discuss.saleae.com/t/starting-capture-using-script/2697
"I am using Logic 2 during development of a product. In order to get certain functionality working in hardware, I frequently follow a sequence of operations like this:
Reset an embedded device
Press “Start capture” in Logic 2
Run some shell commands that produce certain stimuli
Press “Stop capture” in Logic 2
Look at captured data to figure out what’s going on
While step 5 is inherently manual, step 1 through 4 are purely repetitive and a prime target for automation. Steps 1 and 3 are easily accomplished using a simple shell script, but I have so far not found a way to start and stop a capture in Logic 2. The Logic 2 automation API seems to only be designed for headless/automated capture without a human looking at the data, and can’t simply start a capture in an existing tab. Is there any known workaround for this?"
(#82109)
"It might be easier for me to just use the GUI to do my setup, and then just before I start_capture, retrieve what I have done in the GUI -- OR -- be able to specify a start_capture with NO capture configuration, such as:
with manager.start_capture(device_configuration = device_configuration) as capture:
and the automation just uses what the GUI has."
(#81465)
"Can the Automation API be used in combination with normal GUI use of Logic 2? In other words, can I run Logic 2 as I usually do, then when I’m happy with the capture etc, call the Automation API to offload data?"
  • Z
(#80369)
"I have the Python API working pretty well in one script. I was wondering if it is possible to have python scripts that just connect/disconnect and just start/stop recording. Or if these all need to be bundled into one specific python file."
Title edited to encapsulate more use cases
(#78303)
"We are running in a semi automated way. For example, we perform a test shot that automates several different lab equipment and then starts the saleae capture. At the end of that test shot, we want to view the data before moving to the next test shot.
So before moving to the next test shot, we want to view the data which is coming from different sources (different channels) and some windows needs to be fitted.
Our current program does the following:
1. Starts captures
2. Waits for capture to complete
3. Save capture
4. Close and move on to the next shot (user initiated)
What we would like is before we save the capture, or after it saves it, we want to call the API to resize a specific channel so that we can view it."
(#77791)
"I didn't know if there was an API call I was missing that would allow me to attach to an existing session, configure the logic analyzer as required, start the recording and then detach from the session without closing it."
Same request here via Twitter:
twitter.com/cibomahto/status/1612949819655430144
