5
Automation API - Reset the Session Number
Original report of this issue is below:
discuss.saleae.com/t/reset-of-session-number-automation-script/2913
"Hi
I use the example automation script (thread) with Manager.connect.
It is working fine, but I have not found a way to reset the session number.
I would need to close it (or using manager.launch) which will result that some aquistion might be lost.
Is there another way to reset the session number ? Once it reaches 999, the application will stop"
discuss.saleae.com/t/avoid-opening-of-new-session-tabs/3262/3
"I have the same issue. I’ve build an automated testing setup and I’ll be running tens of thousands of captures in a row, where the speed of the tests is essential, so restarting every time after a few hundred sessions is not an option.
Do you have any workaround so that I can restart a capture in the same session? Or remove sessions?"
I
Ivan
Hi, what is ETA for this feature? If Logic 2 is used in CI via Jenkins on windows machine, this session count would reach 999 pretty quick.
Also It would be very useful to be able to force close all opened tabs. It would make possible to refresh and clean-up Logic 2 before new test session.
This feature request is unfortunately not on our backlog at the moment as we are working on other priority projects right now.
Though quite cumbersome, feel free to implement the workaround I described below.
discuss.saleae.com/t/reset-of-session-number-automation-script/2913/2
