Roadmap
Suggest a Feature
Account
Login with my account
Trending Top Newest Oldest
146
Open
85
103
Compare two captures
Open
32
91
Open
39
87
Repeated trigger capture
Open
49
84
Import .logicdata capture
Open
42
62
Overlay 2 or more signals.
Open
17
57
Open
48
57
Open
11
56
Open
13
48
Open
27
