10
Allow Presets to Load on Saved Captures
Original request here:
discuss.saleae.com/t/issue-with-protected-capture/1458
"My use case is this: I capture some data with a low-end computer, and for maximum performance I have all analyzers removed. After the capture I move the .sal file to a better machine, where I have a preset with necessary analyzer configuration, but I cannot load the preset, because the capture is protected. I also cannot unlock the capture - the option is grayed-out. I can manually add the analyzers, but it is very inconvenient. There should be an option to unlock the capture, or at least import analyzers from a preset."
"What would also work for me would be to have switchable analyzers. This way I could add the analyzers I need, but just disable them for the time of capture. Or you could add a global option to suspend analyzers processing while the capture is in progress."
I
Ian
I have the exact same use case. I need to capture long sessions without analyzers since I can get ~20 hrs in less than 10GB vs with analyzers 10GB fills up in less than an hour. I move the captures to another computer to analyze them in a separate logic environment so I don't crash my next ongoing capture, but I can't apply my 7+ analyzer preset on the other computer because the file is now read-only. I would love to be able to apply those analyzers in one shot
(#97655)
"We would like to be able to apply a preset on those captures (reduce height of rows and apply a name to all channels) either programmatically via python API or manually after loading the read-only capture file."
C
Chris
Actually, Logic 1 already had a feature which allowed copying channel or analyzer settings (or both) from one tab to another using the small gear icon on the capture's bottom tab. Would be great if this feature could be also added to the newer Logic 2.
R
Randy
In fact, this used to do this basically in the last major version if I remember correctly. I'm pretty sure it didn't lock the saved capture you were on so that you could just use the setup you had there and grab new data (and potentially save it to a new file)
R
Randy
I have any number of setups (several per board) and I've got some .sal files. I don't mind them being locked but taking the setup from that .sal file and using that for the next capture tab to open would save a whole lot of manual setups.
Peter
The second part ("switchable analyzers." and "suspend analyzers") is of more immediate and general interest to me. In fact: ideas.saleae.com/b/feature-requests/enable-disable-analysers/
  • Avatar
