Roadmap
Suggest a Feature
Account
Login with my account
Trending Top Newest Oldest
133
Open
82
96
Compare two captures
Open
31
85
Repeated trigger capture
Open
49
84
Open
38
83
Import .logicdata capture
Open
40
56
Open
13
54
Overlay 2 or more signals.
Open
15
54
Open
11
53
Open
48
47
Open
27
