Roadmap
Suggest a Feature
Account
Login with my account
Trending Top Newest Oldest
136
Open
83
97
Compare two captures
Open
31
87
Open
39
85
Repeated trigger capture
Open
49
83
Import .logicdata capture
Open
40
56
Open
13
55
Open
48
54
Overlay 2 or more signals.
Open
16
54
Open
11
47
Open
27
